Old 10-20-2009, 08:38 PM
Steve1968LS2's Avatar
Default New caliper finish from Baer...
It seems they had a hard time getting a consitent result from thier old annodizing process, so they came up with a new industrial coating for those that are really going to punish their brakes.
I do believe it's a type of nickle finish and I think this is one of the first sets. Now I just need to get them on the car...
Photography by David Pozzi
Old 10-20-2009, 08:44 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Those look great. What systems are they offered on?
Chris
Old 10-20-2009, 08:50 PM
I think all the six series calipers.. the rotors are 14-inch. We ditched the parking brake system to save on unsprung and rotational weight..
Old 10-20-2009, 09:10 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
These calipers look great!! You gonna have clearence on the front wheels?
Old 10-20-2009, 11:21 PM
We might have to run an 1/8th inch spacer.. it's mostly because of the 14-inch rotors, not the all because of the deeper calipers.
More rotor mass will be a good thing.
Old 10-20-2009, 11:23 PM
Sick.....way better than the red. I always thought it was called an "Emergency" brake. LOL
Old 10-20-2009, 11:45 PM
Actually no.. I've had several brake companies tell me SPECIFICALLY NOT to call it an emergency brake.. but rather a parking brake.
Why? because if you loose you brakes in an emergency that dinky system is just gonna fry and fail under hard load.
Old 10-21-2009, 06:18 AM
ccracin's Avatar
ccracin ccracin is offline
Yeah, actually the "E" Brake name was used when we all had drums on the rear. This basically just added a mechanical actuation method to the existing hydraulic brake package. Therefore you had equally poor (lol) braking on the rear either hydraulically or mechanically in the case of a hydraulic failure.
Looks great Steve. Did David do a solvent test on the back side to see how well the new finish stands up to cleaning? That looks like a great improvement.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 10-21-2009, 08:40 AM
Cris@JCG's Avatar
Cant wait to see what they look like installed on the car!!
Old 10-21-2009, 08:46 AM
That's a good idea.. but I'm chicken! just kiddin.. when I'm up there tomorrow we will test s few things on an unseen area of the caliper.
