Old 11-02-2009, 02:25 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default PPG Primer Question
Does it matter what color DP-90 epoxy to use to seal the metal? My plan is to use black and then follow with a grey high build primer for blocking. Probably a stupid question, but I had to ask.
Chris
Old 11-02-2009, 03:10 PM
comp-spec's Avatar
No it doesn't matter what color DP epoxy you use
DP 90 is black
Pete
Competition-Specialties.com
Old 11-02-2009, 03:16 PM
NovaBlue71's Avatar
NovaBlue71 NovaBlue71 is offline
Not a problem at all putting a black epoxy underneath your 2k primer.I do that all the time. If you haven't opened that dp-90 you can get some southern polyurethanes epoxy instead. Their primers are imo head+ shoulders over ppg products.If need more info on southern polyurethanes you can pm me I'll give you the owner of spi cell number for you to call for more info. Not trying bash ppg but already been down this road too many times and there are alot better quality products out there. You need to remember you are making your foundation for your paint job.What you put underneath a paint job is paramount for the longevity of your paint job.my 2-cents Joe.
