Old 11-09-2009, 05:01 PM
Hotchkis Hotchkis is offline
senior member
Default New - Hotchkis Max Handle Bars for 2nd Gen Camaros
Our 1st gen Max Handle Bars have been so well received, we've answered the call for 2nd gen owners!
1970-81 Camaro Chassis Max Handle Bars
Chassis Max Handle Bars from Hotchkis are a critical component for any high-performance 1970-81 Camaro. The second generation F-Body subframe can flex during hard cornering, altering suspension geometry, tire contact patch and alignment. Hotchkis has solved this problem by applying nature's strongest shape: the triangle. Handle Bars tie the control arms to the cowl and firewall with high-strength tubing and CNC bent brackets for maximum strength and rigidity. The result is incredible handling and driver control that makes the most of your high performance Camaro suspension.
Features:
•Powder Coated, Anthracite Finish.
•Fabricated from 1.5" steel tubing, TIG welded to precision CNC bent brackets.
•CAD designed for superior fit and finish, all parts designed and manufactured in the USA
•Works with most suspension systems and engine installations
•Easy, Bolt In Installation
Benefits:
•Rigidly connects upper control arms to the cowl and firewall, which dramatically reduces chassis, flex during hard cornering and acceleration.
•Prevents changes in geometry, alignment and tire contact patch during high g-cornering.
•Improves driver control, handling and overall feel. Perfect final addition for any street machine, pro-touring car, autocross or road race Camaro.
