Old 11-13-2009, 12:11 PM
av8or32 av8or32 is offline
Default 69 Firebird Electric fans and fuel pump
Any imput on what type of fans/pump would be awesome. I have a 69 Firebird with a 400 pontiac/Muncie 4 spd/600 E-brock carb/mild cam/headers/e-brock intake etc.
Old 11-13-2009, 01:23 PM
70rs's Avatar
70rs 70rs is offline
What radiator are you running? I have seen many people using OE electric fans from Lincolns, Taurus, and a few others. It depends on how much room you have. Derale has a dual 13 inch unit that pulls 4000cfm, it's a little over 200 bucks at summit.
For the fuel pump you can use any mechanical pump from Edlebrock, Holley or a stock replacement one. Just be sure it puts out the right GPM and pressure. A regulator with a gauge is always a help just to be sure. No need to go electric for the pump with your set up. But if you wanted to there are lot's to choose from. Holley blue pump, Aeromotive, Carter, Summit has a complete fuel system with a pump (electric), filter, regulator and line for about 240 bucks. Part number SUM-PUMPKIT7A. It includes -6 braided line (20 feet) and AN fittings and clamps. That would be more than enough to feed your engine. Some of the external electric pumps are VERY noisy though. I have not used any of the summit brands so I can't tell you how loud this one is.
Old 11-13-2009, 02:49 PM
Just be sure to run your fans on relays.... I've seen many people try to run them without and that's serious no no!
I just added a SPAL PWM fan controller to my Nomad... has the first fan come on only half speed and slowly speeds up that fan IF needed - once Fan #1 goes full steam - fan #2 comes on... it also has them BOTH come on when your A/C is on... and has a 'cool down' cycle for 30 seconds after you turn it off... Nice system for nominal additional cost IMHO. Really keeps the noisy fan issue at bay most of the time.
Old 11-14-2009, 04:57 PM
My radiator is 16 tall by 23 wide so I'm limited on size. Why not runa single 16 fan?
Old 11-14-2009, 04:58 PM
my radiator is a new o.e. replacement
Old 11-14-2009, 05:07 PM
70rs's Avatar
There are tons of options for singls fans for you. Take a look over at Summitracing.com and see what they have. You should be able to get everything you need at a reasonable cost. If you see one you like click on it and it will give you the dimensions, CFM ratings and cost.
But like Greg mentioned above, use relays. Don't just do a direct wire with an "on/off" switch.
Old 11-14-2009, 06:40 PM
i've got my eye on a 16"x16" s blade that moves around 2000cfm. Will I be good with that and a Painless relay kit. Also, the kits come in two temp ranges. 200 on 185 off and 185 on and 175 off. Which way would you go?
Old 11-14-2009, 07:25 PM
70rs's Avatar
I would think that 2000 cfm would be enough for your combo. But is there any in that size that move more air? If not then you may want to look into a fan shroud of some sort. More air is never a bad thing when it comes to engine bay heat. Anything you can do to get it out of there and keep the engine as cool as possible under normal conditions. Do you have AC in the car? That will put a lot of extra load on things while it is running.
The Painless relay shoud be just fine. Be sure it is rated correctly for the fans requirements.
Old 11-14-2009, 07:51 PM
I plan on adding a vintage air kit soon. looks like the fan is self-shrouded. I havent been able to find a small enough shroud/fan kit yet. My radiator's only 23x16
Old 11-14-2009, 08:01 PM
70rs's Avatar
If the radiator is a stock size replacement you could use a reproduction version. The electric fan may fit inside of it. You should ask the guys at Autorad if that CFM rating of 2000 is enough with an AC system and whatever your horse power level is. I THINK you would be ok. But better safe than sorry with a cooked engine or stuck having to buy upgrade parts down the road.
