Old 11-14-2009, 04:00 PM
GM Muscle's Avatar
Default stout 355
Ive finally decided to sell my 355 out of my camaro. i recieved this longblock with a chevelle project and sold the chevelle then used this powerplant for roughly 50 miles in my camaro. it killed the transmission and the rearend and the car has sat every since. (~1yr) it ran pretty strong for not really getting into it. i would say under a load it never saw more than 3/4 throttle. i really wanted to respect the break in period. it is a 350 4bolt main bored .030 with arp studed mains with Hbeam rods which also have arp bolts. the block is a GM3970010 block. this motor will come intake to oil pan, alternator to flexplate. this will all include:
4 bolt main 350
hbeam rods
scat crank
Pro lightning 23 degree 235cc angle plug heads done hilt to the tilt
magnum roller rockers,comp pushrods, guideplates, comp solid roller cam, comp triple springs
moroso deep pan(see pics for a slight mishap), matching pickup
windage tray
ported victor jr intake
ati fluid dampner
sfi flexplate
high torque mini starter
stuart high flow water pump
comp cast aluminum valve covers
probably more but thats all i can think of off of the top of my head.
I know this engine is worth a ton more than this but i need the money pretty badly. Im asking 2k which i feel is a very cheap price for just the valve train and heads.
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 11-14-2009, 04:01 PM
GM Muscle's Avatar
Old 11-14-2009, 04:03 PM
GM Muscle's Avatar
Old 11-14-2009, 04:04 PM
GM Muscle's Avatar
Old 11-14-2009, 04:05 PM
GM Muscle's Avatar
Old 11-14-2009, 04:40 PM
pumpgas2 pumpgas2 is offline
Default ???
Do you know how much horsepower the motor produces? My brother has a 1968 Chevelle he just picked up, he might be interested.
Old 11-14-2009, 04:42 PM
GM Muscle's Avatar
i have not dynoed it. hell i barely even went around the block a few times. my buddy builds high dollar boat engines for a living and said he couldnt see why it wouldnt make at least 450hp.
Old 11-15-2009, 09:41 AM
Default 355
Ok. I will run it by my brother and let you know. Thanks!
Old 11-15-2009, 01:18 PM
GM Muscle's Avatar
sounds good
Old 11-15-2009, 03:44 PM
Default 355
Sorry man. My brother said he was lucky enough to get the car. His wife said she would cut his balls off if he spends a dime on this car. Once again sorry.
