Old 11-15-2009, 01:15 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Default rear end width
If i Minim tub my rear end to run 12" wheels will the rear have to be shortened 50" flange to flange ( 72 Chevy Nova)? TIA
Old 11-15-2009, 01:30 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Maybe...
Curtis
Old 11-15-2009, 01:48 PM
70rs's Avatar
70rs 70rs is offline
Maybe...
....and the quality help continues to flow.....
Old 11-15-2009, 06:03 PM
98ssnova's Avatar
Maybe...
Thanks Jerk
Old 11-15-2009, 09:26 PM
awr68's Avatar
awr68 awr68 is offline
Depends on what back spacing you want for the rear wheels. Just because you mini-tub a car doesn't mean you have to narrow the rear end...you basically do that to have more dish (less b.s.) on the wheel. For instance on Jackass it might actually have a wider than stock rear end...look at how much b.s. his wheels have.
The best way to do it is to buy the wheels with the look (b.s.) you want, mock them up (with tires mounted) and then measure for the rear end width.
Tony
'68 Camaro
Old 11-16-2009, 01:59 PM
And that my friends -- is how it's done!
Wheels and tires first - then cut the rear end (or not) to match...
Old 11-17-2009, 07:14 AM
50 is a good width for a 6" BS on a 12" wheels if they would fit in the tubs. but I think your limited for 315s and i would be looking at 11s personally.
Give me a call to discuss, we will dial you in
Frank Serafine
Old 11-17-2009, 08:13 AM
JustinB's Avatar
JustinB JustinB is offline
Listen to awr68! We deal with this all the time. Its a lot easier to build the wheel to the look you are trying to achieve, than measure up the rear and have it cut to length. I could through a bunch a numbers at you as far a backspacing goes, but I would rather figure out what you looking for first.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
