Old 11-16-2009, 04:55 PM
av8or32 av8or32 is offline
Default Manual or Power brakes
I want a slick street driver that would be at home on the track from time to time. Right now I have a manual disc/drum set-up and I'll be upgrading to rear discs in the future. I can do a complete stock type master/booster combo from CPP or go with a Wilwood aluminum master and braided line combo. Opinions pls
Old 11-17-2009, 01:17 AM
deuce_454's Avatar
if you can afford the extra weight... id go with a hydraboost setup.... there is no reason to run manual brakes in a car unless you are a weight fanatic.. a car is supposed to be enjouable.. its somthing you take out to get a wide grin and some extra energy... who cares si manual brakes work for some purist.. its about you having a great time...
that for me.. includes not having to wressle the car into submision.. so i have power steering and power brakes.. and a stereo!
Jake: Hit it.
Old 11-20-2009, 07:50 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
I just started a thread on here recently,and proposed a similar question
got lots of great info to my question. search out my thread and you might find your answers. I even found some great answers to questions I wouldn't have thought of asking
