Old 11-24-2009, 09:33 AM
smokey1010 smokey1010 is offline
Default seat belt bolts
Can you use bolts from the hardware store or do you have to buy the bolts from a dealer. And what size are they.
Old 11-24-2009, 11:36 AM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Many factory seatbelts are held by a bolt with a shoulder that bottoms out allowing the seatbelt to rotate on the shoulder while others bolt a retractor solidly so it will not move and do not have the shoulder. So some require an original or reproduction bolt, while for others you might be able to use readily available bolts.
As for size, if you gave a clue as to what kind of car you're talking about you might get an answer.
John Paige
70 Firebird Esprit, 400 TA clone type "The 14 car"
lab-14.com
Old 11-24-2009, 02:29 PM
67 camaro coupe with no shoulder just lap belts
Old 11-27-2009, 10:43 AM
MODO Innovations's Avatar
They are 1/2"-13 bolts. Like stated above, the bolt has a shoulder on the top to allow the seat belt to swivel. I think to get a normal bolt with a shoulder it might have to be about 2" long or longer.
Shannon
Modo Innovations
940-391-9002
Old 11-27-2009, 02:52 PM
Default See Rick's Camaros
http://www.rickscamaros.com/product....dept%5Fid=3464
another:
http://www.shop.stevescamaroparts.co...969-160270.htm
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
