Old 11-27-2009, 10:12 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default Can i use a steel wire wheel to remove paint and bondo?
I just bought a hand grinder and i want to put a wire wheel on it and remove rust and paint bondo etc. will this harm anything?
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 11-28-2009, 07:22 AM
elitecustombody's Avatar
it'll take a looong time using a wire brush , as long as you don't keep the brush on bare metal for long, it won't hurt anything, I'm using a Porter Cable on high speed with 36 grit to remove 40 year old bondo and paint off 69 Dart right now,it's piece of cake
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 11-28-2009, 01:14 PM
awr68's Avatar
awr68 awr68 is offline
I started with 36 and then whent to 80 on a DA.....
Tony
'68 Camaro
Old 11-29-2009, 09:50 AM
3M makes some great wheels that remove paint,bondo,etc. The problem with using a grinder is you will gouge the metal. It's much safer to use a dual action sander, which is less likely to hurt the metal.
Jeff Allen
J2 Speed and Custom
Old 11-29-2009, 10:45 AM
deuce_454's Avatar
start with a chemical stripper.... id use a DA next, the pads are cheap and it works fast, and strat with a 36 or 40 grid and work your way up... and when you are done with one panel... spray it with epoxy primer, then move on.. (and spend some time keeping the shop clean (or atlieast clean'ish) it will look like a warzone in no time if you dont)
Jake: Hit it.
Old 11-29-2009, 10:57 AM
tellyv's Avatar
tellyv tellyv is offline
If you use chemical stripper make sure you clean up the metal really good before priming it could cause adhesion problems down the road. I use laquer thiner and a red scotchbrite and then I use a d.a. and then clean it again. I also use metal wire brushes alot, like everyone else said dont stay in one spot to long or you'll warp the metal.
Old 11-30-2009, 04:45 PM
FlameBroiled's Avatar
FlameBroiled FlameBroiled is offline
If you want all the material off quick, the buy a 3m clean and strip, or something similar, put it on your electric hand grinder and go to town... ...Fast!!! won't remove or gouge metal... the best way yet ....imoa
www.Eyekandykustoms.com
Old 11-30-2009, 04:52 PM
IndyNova's Avatar
IndyNova IndyNova is offline
i'm not a professional by any means, but i haven't found a chemical stripper that you can buy at a stroe that works worth a ****. I've let it sit on there up to and hour or more, and it really doesn't do anything. I may be expecting it to do more, but I use the 3m paint stripper pad on my grinder, and it works awesome. takes a while longer, but it doesn't put as much heat on it at all. just my .02
Old 12-01-2009, 09:25 AM
BRIAN BRIAN is offline
If it is layed on thick you can use a scraper warmed up with a heat gun it will peal right off in large sections. Then use chemical to strip the rest. Using 36 on a panel puts in a lot of heat and a lot of sanding scratches that can show up later. 36 can go through a panel or take the line or edge right off it.
When using stripper try and lay a piece of plastic over it. It makes it more effective.
Good luck.
Old 12-01-2009, 06:02 PM
IndyNova's Avatar
thanks brian, I'll give that a try.
