Old 12-04-2009, 07:32 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default c5 Corvette shifter in a Camaro
Has anybody done this before? I can't figure out how to hook us the reverse lights and neutral safety switch.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 12-05-2009, 07:37 AM
ohcbird's Avatar
ohcbird ohcbird is offline
Default shifter
The NSS should be hooked to the clutch via a mechanical switch of sorts. make sure it interrupts ground, not power. For the reverse lights, you can use the standard sensor on the T56 (I'm assuming that is what you are using).
Old 12-05-2009, 05:14 PM
bigtyme1's Avatar
Sorry, I guess I should have mentioned I'm using a 4L60E
69 RS Ragtop
[email protected]
Old 12-10-2009, 09:27 AM
1in1969 1in1969 is offline
I've done it if you are still interested? Shawn
Old 12-10-2009, 06:24 PM
bigtyme1's Avatar
Thanks Shawn but do to time, I have decided to go a differeant way. Mike from Muscle Rodz hooked me up with a Mastershift Kit. I will have Twist Machine paddles and the Mastershift technoligy of being able to pull it out of PRN. I always wanted the paddles to begin with now I got the best of both.
69 RS Ragtop
[email protected]
