Old 12-18-2009, 01:23 PM
blown71nova blown71nova is offline
Default FS: SBC Comp Cam Nitrous HP Blower Hydraulic Roller Camshaft 12-419-8
FS: SBC Comp Cam Nitrous HP Blower Camshaft #12-419-8
Hydraulic RollerCamshaft has 2,000 Miles on It...Ran Great...Sounded Great...
Had it in My Small Block Chevy 400 Dart Block with 6-71 Blower..No Nitrous
Took Camshaft out to go to a more aggresive Solid Roller camshaft setup
Check out My Other Listing for Matching Valve Springs..Pushrods...Lifters
Specs From Summit Racing Website:
Brand: COMP Cams
Manufacturer's Part Number: 12-419-8
Product Line: COMP Cams Nitrous HP Retro-Fit Camshafts
Summit Racing Part Number: CCA-12-419-8
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,400-6,500
Intake Duration at 050 inch Lift: 236
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 236 int./248 exh.
Advertised Intake Duration: 288
Advertised Exhaust Duration: 315
Advertised Duration: 288 int./315 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Valve Lift with Factory Rocker Arm Ratio: 0.520 int./0.540 exh. lift
Lobe Separation (degrees): 113
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer-Controlled Compatible No
Grind Number: CS NX288HR-13
Notes: Requires thrust button and wear plate.
COMP Cams Nitrous HP retrofit camshafts are designed to work with your nitrous system to get more power from your engine. Their unique intake lobes allow your engine cylinders to fill better, for more complete combustion. Meanwhile, their exhaust lobes are spread to decrease overlap and ensure maximum scavenging of your combustion chamber. The bottom line is an increased power boost from your nitrous system without any loss of throttle response or torque in street applications.
Costs $265 Brand New From Summit
My Loss is Your Gain
$150 Shipped
Comes with Cam Card Too
Old 12-18-2009, 07:52 PM
6D9 6D9 is offline
Is this a billet core?? Pressed on cast iron gear?? Reduced base circle?
Thanks!
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 12-19-2009, 11:23 AM
#1 no #2 yes #3 no
Old 12-19-2009, 12:10 PM
jwalk's Avatar
jwalk jwalk is offline
Default cam
PM sent
Old 12-19-2009, 04:57 PM
pm sent back
Old 12-19-2009, 05:23 PM
Camshaft Sold!!!!!
