Old 12-19-2009, 08:01 AM
latzoo latzoo is offline
Default In tank fuel pump
I am looking for pictures of a in tank fuel pump install into a stock first gen camaro tank. I have seen some pictures before but now I cannot locate them again. My stock tank is in primo condition and would like to use it to fuel my LS1. Any information is great.
Old 12-19-2009, 09:52 AM
130fe 130fe is offline
Thumbs up
I have a Rock Valley tank for sale that would fit the bill (except for a fuel pump change). It is baffled and ready to bolt in. PM me if you might be interested. The price is negotiable.
https://lateral-g.net/forums/showthread.php4?t=24180
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 12-21-2009, 08:08 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
here is a CRAZY idea for you - requires a little elbow grease...and will not work with a mini-tub.
fuel tank from the last gen rear wheel drive Caprice/Impala. This has all the hook ups to go right to your motor. The fuel sender is a 90 ohm, so it will work with your stock or aftermarket gauge.
Old 12-21-2009, 11:37 AM
Default Tank
What year did you use?
Old 12-21-2009, 01:23 PM
69MyWay's Avatar
That was out of a 96 - but they are all the same on that last rear wheel drive body style.
