Old 12-19-2009, 05:40 PM
Default Gen VI 454 Block & parts
Back on the market.................this is a crazy good deal. The block was this much by itself.....
It's a Gen VI block that has been line honed and decked. It was brand new when I bought it. It's .030 over with a 4.280 bore. It also comes with the timing cover and a remote oil filter adapter.
The crank is a scat cast external balance standard with 4.25 stroke. Rated for 700hp. I also have a professional products balancer and centerforce billet sfi flywheel with low miles.
I have a set of I beam rods(6.385) with ARP cap screws.
The cam is a crane billet hydraulic roller with press on cast gear.(For longevity) .632 lift I/E 244/256 at .050 on a 114 lsa. Made 593hp at 6k and 587 at 3700.
Also have a moroso 6 qt oil pan that fits a Camaro and multiple other cars.
It's all in good shape, the cylinders may need a bore.
I'd let it all go for $1100 firm if you pick it up.
Old 12-19-2009, 05:56 PM
Todd, we need a price
John
Old 12-19-2009, 06:02 PM
Fixed....
Old 12-19-2009, 07:10 PM
This is a 1-piece rear main, correct?
Old 12-19-2009, 10:04 PM
Can be....I have a 2 piece adapter so it's your choice of which crank shaft you want to run. For leaks the 1 piece is better. You could easily put a GM crankshaft in it. I have a centerforce external balance flywheel that would work perfect as well. I'll make you a pacage deal. I don't have room for it.....
Old 01-02-2010, 09:30 PM
It's crated up and no reasonable offer will be refused. It needs to go down the road.........
Old 01-03-2010, 08:16 AM
HA! I'm trying to fight the urge . Someone needs to pick this up. Didn't you guys hear they shut the plant down and aren't making BBC's anymore hehe.
John
Old 01-04-2010, 03:44 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Bump for my buddy Todd!
Old 01-05-2010, 09:04 AM
g356gear's Avatar
g356gear g356gear is offline
4 bolt main?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 01-05-2010, 09:11 AM
Yes sir......
