Old 12-26-2009, 07:55 PM
fillpot fillpot is offline
Default 69 camaro 4 wheel disc question
Guy's going to be converting my camaro to disc soon but I may have a problem,I'm wanting to run my rally wheels for now,and also my 9in rear has the small ends,is there anyone making something to clear the 15in wheels.THANKS!
Old 12-26-2009, 09:02 PM
6spdcamaro 6spdcamaro is offline
these might work
http://www.baer.com/products/complet...ous-street.php
Old 12-26-2009, 09:05 PM
The factory did it with small rotors. I'd bet they are 11".
Old 12-27-2009, 04:10 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
I have 12" front discs in a C4 setup using 15" rally's. I needed a 1/4" spacer for caliper clearance.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 12-28-2009, 10:27 AM
Apogee Apogee is offline
The factory C3 Corvettes ran 11.75" x 1.25" rotors with 4-piston calipers front and rear and squeezed them into 15's. You'd need something custom for the Ford 9" rear, but we might be able to help you out with something there. Wilwood makes some nice aluminum replacement C3 calipers that shed almost 30 pounds from a set of calipers and modernize the piston seal design.
How do you primarily intend to use your car? What's the budget if you don't mind me asking?
Tobin
KORE3
www.kore3.com
Old 12-28-2009, 04:53 PM
The car is basically going to be a cruiser and some 1/8 mile drag racing,it has a stock LT1 in it now but I'm going to be putting a ls2 that I have or biulding some type of bigger cubed LS motor.This afternoon I found some small bearing backing plates that I can use in the rear with a currie 11in brake kit I already had.I may just run the drums until I get my motor situation figured out.THANKS FOR THE REPLY!
