Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 12-27-2009, 05:43 PM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Default Electronic throttle body
Im looking for a 90mm electronic throttle body. ls2 / ls7 version #1 with a silver colored throttle blade.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 12-27-2009, 10:46 PM
1badchevelle 1badchevelle is offline
You are a day late. I just sold one yesterday. I will see if I can get another one.
Old 12-28-2009, 07:57 AM
scherp69's Avatar
scherp69 scherp69 is offline
What's the difference between that one and the stock L92 truck throttle body? I have the L92 one, never fired, if it will work.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 12-28-2009, 08:16 AM
Bow Tie 67's Avatar
The LS2 is a 90mm the L92 is 88mm if memory serves me correct.
Matt
Old 12-28-2009, 09:13 AM
Matt what is the diff on the yellow blade and the silver t/b's ?
Old 12-28-2009, 09:54 AM
Bow Tie 67's Avatar
Well from what I have been told they have different throttle position sensor ramping. I currently have one from an 08 vette with the gold blade. Last summer I fought an intermittent P2101 code which puts the car into a limp mode. The only limping it allows is to coast over to a stop. The first version TB " may " cure this problem. I also plan on soldering all the connections for the TB circuit. I have also been told the base GM ETB ECU mapping must match the ETB and the throttle pedal. I may have to get a different pedal as well. I wont have a definitive answer until spring.
Matt
Old 12-28-2009, 07:28 PM
I did a bit of research on that code. Seems to be common on the vettes. Looks like the TPS gets carbon build up( not sure how). If you like I can send you mine to test out and see if that will solve your problem . Its a new take off and my motor will not be ready for some time. PM me if you like.
Old 01-03-2010, 04:59 PM
Did you ever find the t/b? I have another one coming in from a 9k car.
