Old 12-28-2009, 04:32 PM
byron byron is offline
Default 6sd auto
I was wondering if anyone has used the tci 6sp electronic trans yet. Im looking to install it in a camaro project with with the paddle shifter assembly. they rate them out of the box to take about 800hp. anyone burst one yet? Id like to know how reliable the paddle shifter assembly is because I will not have a console shifter to go with it.
Old 12-28-2009, 04:47 PM
camcojb camcojb is offline
you'll still need a physical shifter to move from park to neutral/reverse/drive etc. The paddle shifter just gives a manual mode with paddles for upshift/downshift, but won't handle the park/reverse/neutral/drive duties.
Old 12-31-2009, 04:09 PM
the rep at sema told me that you can use there key pad deal to move the out of park, reverse ect. Its small enough to hide and still make it accessible. just hope the trans is reliable
Old 12-31-2009, 04:23 PM
ok, then this is different than what I've used and seen. The trans should handle a fair amount of power, I've seen them beat on a ton in the CTSV's.
Old 12-31-2009, 04:31 PM
Sandbagger's Avatar
Sandbagger Sandbagger is offline
If I heard correctly that set up is on the high side of five grand
OUCH...
Old 12-31-2009, 04:42 PM
$6200 after the smoke clears... nasty I know but paddle shifters and six speed kinda turns me on....
Old 12-31-2009, 05:42 PM
Sandbagger's Avatar
Somebody is listening . Less than an hour after I posted that I got a news letter from Kiesler .
Im putting together a C4 and will probably still go with the five speed . The paddle thing reminds me of my nephew s 5 & 7 on there PS2
Old 12-31-2009, 06:05 PM
whiplash911's Avatar
whiplash911 whiplash911 is offline
pardon my "newbieness" but are we speaking about the same paddle system that is offered by "twist machine?
i ask cause i am considering my options about a paddle shift system as i iron out the details for my soon to be announced build
Old 12-31-2009, 06:34 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Isn't this thread about the 6spd re-jiggered 4L80E tci is selling, not a 6L80E like in the gm cars?
Scott from NJ
Old 12-31-2009, 07:01 PM
i was using it to compare the bowler 4L65E-55097 transmission .... i only asked cause my transmission has not been bought yet but still in the "planning stage" that being said ... i do now know what powerplant torque figures are and i have more options than i thought i would have
