Old 01-01-2010, 07:50 PM
Default 1972 Procharged 581 Camaro
I have been a member here for some time, usually just reading threads for my own knowledge and trying to help out with a little input where I can. A few people asked for a build thread of my project so I will start one today. The project has been slow going, but I am patient and determined to make it the way I want it. I have no sponsors, but I have been in contact and got great advice from some of who I think were the best people to help me on this project.
There will be a kind of evolution of the build as I have plans to do some racing in different events, it is however built as a street car. The cage is installed for my safety (and the passengers) to do the events that I want to do. Although for some a street car has different meanings, it will have all functional mandatory equipment and will be driven on the street. Its not meant to appear stock, its not meant to be stealth, its just meant to be what I want and drive like I want.
So, I will start where I started, with the motor.
581 cubic inch big block chevy.
One giant set of air flow research heads.
Edelbrock intake.
The F2 procharger.
Old 01-01-2010, 08:02 PM
Then when we were all done it went on the dyno. At the time, to be safe it ran on 80% pump gas and 20% 110... maybe 116 octane fuel. It was only run to 5500rpm because at the time I had no intercooler and the inlet temp was getting warm. We used the pullies I had at the time wich made 17lbs of boost. I will probably not spin it too high unless I need to, but the cam is suppose to make peak power at 7400 rpm. It, along with the carb and the procharger, were purchased through Steve morris who is the procharger Guru.
Here it is making a little noise. Its not a very good video but its all I had at the time.
[IMG][/IMG]
Old 01-01-2010, 09:20 PM
Next the car was stripped of its old cage and the new one was started. A perimeter frame was slid inside the rockers, and almost all but a small section of front frame was removed. Here are a few pics of the work while it was being done.
Old 01-01-2010, 09:35 PM
pokey64's Avatar
pokey64 pokey64 is offline
That is one serious looking cage system. Nice build!
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 01-01-2010, 10:36 PM
I love the cage, but did not enjoy painting it in my garage.
Old 01-01-2010, 10:46 PM
70rs's Avatar
70rs 70rs is offline
Very, very cool! Thank you for starting this thread.
Old 01-02-2010, 07:07 AM
LSXZ28's Avatar
LSXZ28 LSXZ28 is offline
Lookin great! Some serious tubing going on there!
Bret Shook
GM EFI Tuner
1980 Camaro Z28 project (For Sale)
2002 Trans Am WS6 mid 9's on pump gas and drag radials - sold
1972 Camaro ground up resto-mod - sold
Old 01-02-2010, 08:20 AM
While it was still in the chassis shop I had them build me a set of 2 1/2" x 5" headers. The 5" collector is made flat to keep as much ground clearance as I can.
After I got it home I had them coated.
A couple shots of them in the car
Old 01-02-2010, 08:25 AM
californiacuda californiacuda is offline
Thanks for sharing, what procharger are you running and did you think about turbos?
Old 01-02-2010, 08:40 AM
66LS7's Avatar
66LS7 66LS7 is offline
That video of the engine on the dyno sounded great, can't wait to see more pics. I see you've set that motor back quite a bit, looking good.
Randy(D&Z Customs LLC.)
[email protected]
1-262-347-9741
