Old 01-02-2010, 08:52 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Thumbs up Running a 4L60E behind a 455 Pontiac
Is this possible? I know the bell housing would be different, does anyone here know of a supplier that has this conversion? I have the 4L60E and converter. thanks!
Jim
Old 01-02-2010, 08:55 AM
deuce_454's Avatar
it should be possible even with an adapterplate... but depending on the output of 455 you will need some modifications to make the transmission last.. also you will need a controller like compushift to operate the transmission
Jake: Hit it.
Old 01-02-2010, 09:36 AM
130fe 130fe is offline
Thumbs up
Here is an adapter that will help you out. http://www.summitracing.com/parts/TC...art=TCI-230001 Hopefully the 60 holds up to the 455.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 01-02-2010, 10:27 AM
As I've been told -- the 60E is only a 700r4 with "electronic shifting".... having said that -- and if that is true - then I would say that the other comments on having it "built" would be appropriate. I'm running a BowTie Overdrives Stage 3 700r4 behind a 427 small block that put down 489 RWHP.... I hammer the heck out of it - but have relatively small rear tires (I call them - "my slow blow fuse")... so am not really being that hard on the trans since I can't hook up.
Old 01-02-2010, 10:43 AM
tjbruning tjbruning is offline
www.quicktimeinc.com
RM-9070 Buick/Olds/Pontiac to 4L60E Auto Transmission
  • Transmission = 4L60E Automatic
  • Engine = Buick/Olds/Pontiac All V-8
  • Flexplate = 166 tooth
  • Weight = 21#
  • Fork bracket, full engine plate, and grade 8 bolts included
