Old 01-03-2010, 10:56 AM
*hotrods*'s Avatar
*hotrods* *hotrods* is offline
Default Afr 227 Sbc, 406 Nos Short Block, Brodix Hvh
AFR 227 COMP SERIES Heads with extensive port work by Joe's Porting. Heads come complete with 2.10/1.60 stainless valves, milled by AFR to 60CC, both standard and Stahl exhaust patterns. Upgraded 8003 Roller Spring 1.550 O.D. w/Electroplate Polishing that are rated to 740 lift. There isn't any casting marks on the heads. The ports and chambers are polished. All the oil surface areas are polished. The pushrod area is polished and cleared for the Jesel Pro System if you ever decide to go in that direction. And finally, the outside is all polished. I purchased these heads in September and they have about 10 passes on them. I'm moving up to 14* 455 SBC. These heads should flow in the 330's @ 700. I have over $3000 in them and will let them go for $2200 REDUCED $2100 SOLD
Have a full set of Harland Sharp 1.65 correct offset roller rockers that also are like new and a Jomar Stud Girdle that I will sell to purchaser of heads for $225 or $300 without heads. SOLD
SBC 406 NOS engine with about 10 passes went 10.34 in 3400lb truck. Scat lighweight 4340 crank, Scat 4340 H Beam Rods, JE NOS Dome pistons with Hellfire Rings. Splayed Billet main caps, balanced and assembled. $2900
Brodix HVH 4500 HV1000 intake with fogger all ready drilled. Gasket port matched and about 2-3 inches in. Intake is like new. $295 SOLD
Kevin Turner
Maysville, KY
3-69 Camaro's
02 S10 extended cab that's street legal & runs 10's on motor and 9's with spray.
04 GMC Denali Quadsteer truck black with black 22's.
04 GTO LS1 that loves to be sprayed and meet imports on the street.
Old 01-05-2010, 05:25 AM
*hotrods*'s Avatar
New Price On Heads $2100
Kevin Turner
Maysville, KY
3-69 Camaro's
