Old 01-06-2010, 09:22 PM
Mover's Avatar
Mover Mover is offline
Default Safety wiring rotors ?
Can someone tell me how to safety wire button head cap screws? Does the wire go over the top of screw or the side? I did a search on the net and did find any information.
Thanks!
Craig
69 Camaro RS 327
69 Camaro Custom twin turbo
70 Bonneville 455 Convert "the boat"
Old 01-07-2010, 03:17 PM
JeffT JeffT is offline
Right or wrong, idk...but I routed the wire around the side of the button head as best I could vs. pulling straight back across the head.
Old 01-07-2010, 03:52 PM
Mover's Avatar
Hey thanks! I kind of did the same thing you did and went around the button head. As long as the don't back out i guess it's good
Craig
69 Camaro RS 327
Old 01-07-2010, 05:53 PM
smhigh's Avatar
smhigh smhigh is offline
http://www.tpub.com/content/aviation.../14014_116.htm
Take a look at this and see if it helps....
Old 01-07-2010, 07:32 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
It should go around the bolt head and also should be tightening the bolt otherwise its pointless to have safetywire. hope that helps
Old 01-07-2010, 07:58 PM
1Bad68Cat 1Bad68Cat is offline
Default Safety Wire Documents
You can try going to this site: https://assist.daps.dla.mil/quicksea...t_number=41887 and look at revision J. It has a PDF file on how the military safety wires components. Also wilwood has a PDF document as well on how they want customers to safety wire their products. The link is here: http://www.wilwood.com/PDF/ds386.pdf
