Old 01-07-2010, 12:11 PM
3_z28camaro's Avatar
3_z28camaro 3_z28camaro is offline
Default Opinions on this shaved door handle kit
I searched around and did not see this mentioned elsewhere so I was curious if anyone had any experience with this specific shaved door handle kit primarily concerning the bear claws? Also are 35 lb solenoids enough for a 1969 Camaro?
http://www.summitracing.com/parts/ELI-94100/
1971 RS Camaro
Old 01-07-2010, 03:49 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
I bought an electric life kit about 4 years ago. I went to install it about a year later but the wiring diagrams were way off, the wire colors didn't even match. because a year had passed, electric life wouldn't take it in return, so last year I got all the wiring figured out (don't like to rush into stuff..hahaha) and hooked it up.
I have the kit with 50lb pulls in my '69 Camaro. I have no poppers and the doors still open fine. I have to give Pete over at Comp Specialties props on that part though, because he helped me with setting up the solenoids and he pretty much rebuilt my inside door latches so they work better than new.
I see no reason to try and install the bear claw latches on a Camaro. that is more for streetrod set-ups
Old 01-07-2010, 08:02 PM
The only reason this particular kit caught my attention was because both of my door latches are shot and I was thinking I could save part of the hassle of the install using the supplied bear claw latches.
Thanks for the reply.
1971 RS Camaro
