Old 11-17-2005, 04:43 PM
hotwheels's Avatar
hotwheels hotwheels is offline
Default Head Gasket price shock
Last nite i emailed a larger company about purchasing a set of those multi layered cometic head gasket's, (.073 thinkness).....
Guess how much?
231.00 wowza......i have never run a head gasket that cost's that much and i have had some pretty nice engine's.
What are your thought's on a good head gasket?
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 11-17-2005, 04:49 PM
sinned's Avatar
sinned sinned is offline
4 cylinder MLS gaskets for stock engines are typically 125.00 or so.Try buying a gasket for a bigger deisel...~500.00 or so.
Dennis
Old 11-17-2005, 04:52 PM
protour's Avatar
protour protour is offline
Guess how much?
Well for 1, Cometics are pretty much the best gasket on the market, and 2 they are re-usable!
-Matt
72 Chevelle. 370ci LS, Forced inductions S476, SpeedTech Suspension equipped, C6 Z06 brakes
Old 11-17-2005, 05:59 PM
hotwheels's Avatar
great points........
What i am looking to do is lower the compression on my new short block....it is 10.5 to 1 right now, and probably not the best for my twintubo's. The .073 gasket would get me down to around 9.6 to 1, and with my nitrous, should keep the car running at safe limit's, most of the time.....
Insanemustangs
Old 11-17-2005, 06:28 PM
Blown353 Blown353 is offline
$231 sounds rather high. Cometic should be able to hook you up for $150 or so. I paid right around $140 last year for the pair of Cometics which currently sit in the package adorning the wall of my garage (the surface finish on my block was borderline for MLS gaskets and I didn't want to chance a leak, so I used Fel-Pro's instead...)
Troy
1969 Chevelle
Old 11-17-2005, 07:16 PM
TEDDYS CAMARO TEDDYS CAMARO is offline
Give Me A Part Number And I Will Get You My Price. I Am A Distributor.
Old 11-17-2005, 08:20 PM
hotwheels's Avatar
Right on man, i appreciate the offer..........I don't have the part number per say since i was unsure of the thickness i needed, but from what i gathered from the email, the part number may be C5511-074 My engine is a 302 bore .030 over, which would be 4.030 and the thinkness i need is .074.....according to what i can find from a google search, the part number would therefore be C5511-074 C5511 being cometic's ford number for 4.030 and the .074......
I think....hehehehe
anyways, i thought his price seemed pretty high too........i know cometic's aren't cheap, but that seem's almost 100 bucks to high....
thanks, hotwheels
Insanemustangs
Old 11-17-2005, 09:08 PM
jonny51 jonny51 is offline
My cometic gaskets for my SBC were 76.60 each.
Old 11-17-2005, 10:59 PM
hotwheels's Avatar
yea, that seem's like a much better price.......better then 115 each.
Insanemustangs
Old 11-18-2005, 04:40 AM
Smack_talker's Avatar
Smack_talker Smack_talker is offline
+1 on the Cometics. I have a set on my car, .080 thick for boost. They are the best out there. Can somebody get me a price for a new set on a 302 Ford.
