Old 01-13-2010, 09:46 PM
1964_442's Avatar
1964_442 1964_442 is offline
Question T56 Input Shaft Size Needed !!
my t56s input shaft is damaged...
can someone help me to find this exterior diameter (green line) and this height (yellow line) please , the are no replacement parts here to measure it.. for a 1998 camaro ls1
Old 01-14-2010, 10:02 AM
projectile's Avatar
projectile projectile is offline
I've got a 97 LT1 T56 apart on the bench. I believe the synchro surface should be the same.
Yellow line height is .472" (12mm)
Green line dim. is 2.480" (63mm)
Green line dim. has a 30 degree X 1mm champher
Major diameter of champher is about 2.510" (hard to measure without drawing it on CAD)
Ray
Old 01-16-2010, 08:15 AM
1964_442's Avatar
thanks a lot
