Old 01-17-2010, 09:49 PM
blue67ss's Avatar
blue67ss blue67ss is offline
Default 5sp trans swap help?
I just purchased a 5sp trans from a 91 v-8 camaro. I have the bellhousing that came with this trans which kinda tilts the trans towards the driver a few degrees. Right now my car has a 350 turbo and im wanting to do the swap. Can someone tell me what all problems i might run into in this swap or should it be pretty straight forward. My car already has the manual pedals so i wont have to deal with that. The motor in my car is a 87 model 350. What flywheel/clutch should i tell them at the parts store i need? should i use this bellhousing or a bellhousing from a 4sp which i also have that doesnt tilt the trans? Ideas on clutch manual / hydro? If someone has already done this swap and has this info I would greatly appreciate it. Just thought of another question drive shaft and crossmember what has to be done there? Any and all info would be greatly appreciated. thanks
