Old 01-28-2010, 10:00 AM
latzoo latzoo is offline
Default Underbody
I am about to primer my 67 camaro after finishing all the metalwork and was wondering what everyone thinks I should put on the bottom of the shell. The car is on a rotissere so this is the best time to primer/ undercoat the bottom of the car. Maybe some POR15or some other product that I have not heard about. Thanks.
Old 01-28-2010, 11:11 AM
jy211's Avatar
jy211 jy211 is offline
have you checked out second skin?
Old 01-28-2010, 11:24 AM
67rstbkt 67rstbkt is offline
I'm thinking I might use epoxy primer followed by U-pol Raptor bedliner. I used this stuff on my truck and although it seemed a little too thin for a bedliner, I think it would make an excellent undercoating. Do a search for Lenie in the project updates section, he used it on the underside of his 68 Firebird.
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
Old 01-28-2010, 09:37 PM
caper150's Avatar
caper150 caper150 is offline
I'm close to doing the same on mine and was wondering the same thing, like to hear what others have to say. I was thinking epoxy or POR-15 followed by some sort of bedliner.
__________________________________
Darryl
My projects
1965 Ford Galaxie Big Block and 4Doors Project HULK
1966 Ford Galaxie 2 Door Sedan Project unnamed 4.6L Crown Vic runnig gear
Old 01-28-2010, 11:32 PM
Travis77's Avatar
Travis77 Travis77 is offline
Although I have not quite got to the uncoating stage, I believe I may try this approach. I am surprised more have not gone this route.
67 Fastback 418, hogans upper, FAST efi, Richmond 6spd, global west front, homebrew 3-link, mini tubbed, baer brakes with hydroboost, pilot sports on Ze Boost wheels
Old 01-29-2010, 01:28 AM
xpsled xpsled is offline
Por-15, I have been using it everywhere on my build and am really happy with the results. I am very skeptical of any kind of body deadner/bedliner. The reason that i say that is that most rust problems i have seen develop underneath cars are due to the deadner cracking after time and trapping moisture underneath.
Go the Por-15
Old 01-29-2010, 05:13 AM
deuce_454's Avatar
Go the Por-15
for rust protection there is only one way to go and that is a wax based undercoating... but it is a mess, and doesnt earn you street credit
Jake: Hit it.
Old 01-29-2010, 12:12 PM
Default Success
Thxs Travis 77
Old 01-29-2010, 08:46 PM
elitecustombody's Avatar
the first thing applied to the metal should be epoxy primer,then whatever material you choose, stay away from POR-15 unless you want to strip and re-do everything in couple years
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 01-29-2010, 11:31 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
http://streetmuscleaction.com/chassi...ody-protector/
Was that stuff textured like bedliner or smooth? I couldn't tell for sure, but it looked like paint to me. If so, I like the look.
Chris
