Old 01-28-2010, 10:25 PM
Famous68 Famous68 is offline
Default short or long waterpump?
so im trying to figure out what the difference is between the 2 and witch one is more comon on 1st gen camaros. im only going to be running p/s pump and alternator...and i would like them as low and compact as possible...any advice would help..
.....dose the hamonic balancer make a difference?
Old 01-28-2010, 11:21 PM
70rs's Avatar
70rs 70rs is offline
You can run either pump.
What parts do you have right now for your front drive set up? Which alternator mount and which PS pump mount?
Maybe post some pictures if you are not sure and someone will help you identify them and determine which pump to get.
As for the balancer it makes no difference which one you have, the pully mounted to it will matter though.
If you don't have any of the front drive set up yet, you can run either pump (would suggest the short one if clearance will be an issue with the radiator) and buy your mounting brackets and pullys to match.
Eric
Old 01-29-2010, 09:02 AM
Efi69Cam Efi69Cam is offline
68s had short pumps orginally.
Short pumps work best with electric fans long pumps work best with mechanical.
Old 01-30-2010, 05:33 AM
BigVin BigVin is offline
I have a 68 with a 350 and I have a long water pump and elec. fans with no problems. The alt. p/s are very compact if you run a short pump it will not be as compact. I would go with the long.
Vin
