Old 01-29-2010, 08:25 AM
g356gear's Avatar
g356gear g356gear is offline
Default 6.2 liter LS valve problems??
My sister has a 2007 Escalade Ext with the 400hp 6.2 LS motor. Last Friday the truck did a heavy shimmy shake and stopped dead on the hwy. Long story short, the dealer pulled the valve cover and discovered the engine had swallowed a valve into the motor. Dealer said this is a common problem with the 6.2 and that they will do a full longblock crate motor exchange. Apparently these motors have a "hardened" valve that has been breaking from being too hard to the point of being brittle. Truck has 53000 miles. Has anyone seen or heard of this problem? Dealer said it is a common and they don't even bother to repair the motors anymore, they just change them out.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 01-29-2010, 10:41 AM
andrew5's Avatar
andrew5 andrew5 is offline
yep that's the right story.i run a chevy service dept.we used to replace the heads,but gm came out with a bullitin to replace the engine.
Old 01-29-2010, 11:00 AM
70rs's Avatar
70rs 70rs is offline
Is this the factory stock L92 heads that are failing?
Eric
Old 01-29-2010, 11:11 AM
youthpastor's Avatar
please ship old motor to...... Tacoma Washington - I'll fix it!
seriously- thats how we roll in at the used car market too. quicker and cheaper to replace complete engines than mess around with gaskets and machine labor
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 01-29-2010, 12:46 PM
z4me69 z4me69 is offline
it's verry common i have fixed 5 or 6 of em
Old 01-29-2010, 12:52 PM
jy211's Avatar
jy211 jy211 is offline
good to know this stuff as I have a new crate one of these sitting in my 55' chassis.
Old 01-29-2010, 01:57 PM
70rs's Avatar
Is this the L92 engines that are having the problems? Is it specific to any year or model it was installed in?
Eric
Old 01-29-2010, 02:11 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
So far as I've heard, it's an L92 issue, not an LS3 issue. Here's the only thing I could find on a quick Google search: http://forum.grrrr8.net/showthread.php?p=177239
Note that Denali's came with L92 engines, not LS3s.
Old 01-29-2010, 02:36 PM
70rs's Avatar
Thanks Mike. That will give me some information to go with, and search for more. I am going to use L92 heads and want to be sure I don't miss something important like valves breaking off.
Eric
Old 01-29-2010, 03:07 PM
andrew5's Avatar
http://gsi.xw.gm.com/si/showDoc.do?d...274537&from=sm
