Old 01-30-2010, 04:56 AM
Rick Giles's Avatar
Rick Giles Rick Giles is offline
Default Best Company To Buy Stainless Turbo Piping From?
Can anyone tell me, hopefully from experience, where to buy stainless turbo piping from? Just bought an unfinished project that needs piping from 2 turbos to 2 intercoolers.
Old 01-30-2010, 06:12 AM
64duece 64duece is offline
Most of the normal stuff we do, Stainless Works offwea very nice bends at a reasonable price. We use these on most of our turbo header builds.
If you need the nicest quality available, then SPD or Burns Stainless would be your next option but, more expensive.
Dennis
Moore Racecraft
Old 01-30-2010, 03:03 PM
Best place and pricing anywhere - http://www.mandrel-bends.com/catalog/
Jeff Allen
J2 Speed and Custom
Old 01-30-2010, 09:43 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
What about McMaster Carr. They used to sell 304SS tubing. I know a friens of mine used MC on his turbo Mustang.
Chris
Old 01-31-2010, 06:46 AM
Fluid Power's Avatar
http://www.burnsstainless.com/
Another option, a little spendy, but nice stuff.
Darren
Old 01-31-2010, 11:23 AM
E.rodz's Avatar
E.rodz E.rodz is offline
I don't know if you are set on stainless but aluminum is a common thing when it comes to intake piping. you can find plenty of kits on fee bay they come with 2 90s 2 45s 2 straights 2 180s and couplers for about 120 bucks.stainless can be used but great care must be used for it is very easily warped and when you weld the outside the inside should be purged with argon to prevent sugaring of the inside of the piping.just my 2 cents worth.good luck with whatever you decide.
my name is Eric Hokenson I have a dream of building ten of the coolest hot rods out of my home shop wish me luck I am going to need it! - more pics on my web site www.erodzcustoms.com this is just for fun and i am NOT looking for any more work!
Thank you supporting sponsors! without you guys there is no way I could do this myself !
Modern automotive performance,Ring bros.,Yank convertors,extreme drive systems,Cj tunes,race coatings stainless works,Modern Automotive Performance.all of these shops have the experience to get your car to the top.
Old 01-31-2010, 07:47 PM
Rick Giles's Avatar
Thanks guys! That is all good info. I think stainless would look the best since the hot side is already done in stainless.
Old 02-01-2010, 08:23 PM
ssinister ssinister is offline
FWIW Aluminum should also be purged with argon on the inside of the pipe. Mild steel piping is pretty much the only thing that should be welded without a inert gas shielding the other side of the weld.
Old 02-03-2010, 01:12 PM
Blown353 Blown353 is offline
Burns, SPD, and Woolf Aircraft all make very high quality stuff. I used SPD and Woolf for my 321 stainless up-pipes to the turbos, the 321 wastegate tubing, and 304 stainless downpipes. Their bend quality is superb!
Woolf also offers some very tight 1D radius bends that the other guys do not offer, so keep that in mind if you have a "tight spot."
For the remainder of the exhaust from the downpipes back to the mufflers I bought all the 304 stainless bends and hardware from Columbia River. While the tubing is good quality their bends aren't quite as nice as Woolf, SPD, or Burns. They're not crushed, wrinkled, or rippled, but expect a few minor die marks and lots of grease left inside from the forming mandrel. Columbia River's stuff is not as pretty as the "high dollar" guys but for the exhaust under the car it's plenty good in my opinion and substantially cheaper. Don't get me wrong, CR's bends are still nice but they are not as perfect as SPD, Woolf, or Burns. The straight tubing itself that CR uses has Made in USA ink stamps on it-- so that's good!
FYI, if you're building tubing from the turbo outlets to the intercooler I would recommend using aluminum. It has a much higher thermal conductivity than stainless and will "shed heat" from the hot air leaving the turbos more effectively than stainless which has a much lower thermal conductivity and tends to keep the heat in.
As mentioned, remember all the necessary welding procedures for stainless tubing. Tungsten size, heat range, backside shielding (flux or backpurging), etc. A poor stainless weld is very brittle and an overheated stainless weld is also susceptible to corrosion.
1969 Chevelle
Old 02-10-2010, 08:47 PM
Rick Giles's Avatar
Thanks for the help! Aluminum does sound like a good choice now.
