Old 02-03-2010, 09:02 PM
g356gear's Avatar
g356gear g356gear is offline
Default ///
Please delete
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 02-03-2010, 09:39 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Originally Posted by g356gear View Post
Does anyone know which would be a better set-up for me to run on my 69? I currently have the stock rebuilt TH400 but I have never really been happy with it. I miss the 4 spd I had in my 64 Vette. Looking at the Hurst TREMEC TKO 5 SPD conversion package for my car, I see they have the hydraulic option for the set-up. I am a little concerned that the regular NOS set-up wont clear my Lemons headers. They are 2 1/4" tubes with 4" collectors. In terms of installation, would it not be easier and cleaner to go that route? I want to do as few modifications (cutting) to the car as possible.
Why don't you ask Lemon's if their headers will clear a stock clutch linkage?
Old 02-04-2010, 08:30 AM
g356gear's Avatar
I was going to but thought someone might have a quick answer on the board.
Old 06-27-2010, 09:58 PM
Saleen04 Saleen04 is offline
Exclamation T56 Help Needed for 70 Chevelle Install???
Same questions here.
