Old 02-04-2010, 03:42 AM
xpsled xpsled is offline
Default 2008 Cadillac CTS-V Brembo brake rotor dimensions
Hi just after some info on brake rotor dimensions. What thickness/offset/diameter rotors came on 2008 Cadillac CTS-V Brembo.
I have found a set of calipers(front and rear) very cheap for the conversion into my 1965 Falcon. I need to know the dimensions especially the thickness before i buy the calipers to make sure that I am able to get blank rotors the same dimensions drilled to ford stud pattern.
Any help would be greatly appreciated.
Old 02-04-2010, 06:36 AM
andrew5's Avatar
andrew5 andrew5 is offline
Default Brakes
here are the dim i found.Disc Brake Component Specifications
Application
Specification
Metric
English
Front Brake Pads
Taper
0.15 mm
0.006 in
Front Brake Rotor JE5
Rotor Diameter
316.0 mm
12.44 in
Rotor Minimum Thickness*
28.5 mm
1.122 in
Rotor Maximum Allowable Assembled Lateral Runout
0.06 mm
0.002 in
Rotor Maximum Allowable Scoring
1.50 mm
0.059 in
Rotor Maximum Allowable Thickness Variation
0.025 mm
0.001 in
Rotor Thickness (New)
30.0 mm
1.181 in
Front Brake Rotor J55
Rotor Diameter
345.0 mm
13.583 in
28.5 mm
1.122 in
0.06 mm
0.002 in
1.50 mm
0.059 in
0.025 mm
0.001 in
30.0 mm
1.181 in
Rear Brake Pads
Taper
0.15 mm
0.006 in
Rear Brake Rotor JE5
Rotor Diameter
315.0 mm
12.598 in
21.5 mm
0.846 in
0.06 mm
0.002 in
1.50 mm
0.059 in
0.025 mm
0.001 in
Rotor Thickness New
23.0 mm
0.906 in
Rear Brake Rotor J55
Rotor Diameter
339.0 mm
13.347 in
21.5 mm
0.846 in
0.06 mm
0.002 in
1.50 mm
0.059 in
0.025 mm
0.001 in
Rotor Thickness New
23.0 mm
0.906 in
* All brake rotors have a minimum thickness dimension cast into them. Replace any rotor that is worn or machined below this specification.
not sure which brake option is the v.
Old 02-04-2010, 10:56 AM
rokketride rokketride is offline
There wasnt a CTS-V in 2008, that was the first year of the CTS redesign, no V-Series variant.
For the above posted numbers, the 316mm JE5 disc is standard on all trims of CTS in 2008 (and beyond). The 345mm J55 disc is the disc that comes in the Y43 Performance package on regular CTS.
The <2007 CTS-V Brembo brakes I believe 355 front and 365 rear.
For the 2009 CTS-V Brembo front disc, you are looking for 380x32 mm. Rears are 373x28mm.
