Old 02-04-2010, 07:37 AM
Serpa69's Avatar
Serpa69 Serpa69 is offline
Default C4 13" Brake Rotor Question
Does anyone know a part number or sell a front disk that is thicker than the factory. I did a C5 caliper and a C4 13 inch disk setup on my 69 camaro. The setup I used the SpeedTech offset brackets. The car stops great and works I just do not like how far the pistons have to come out of the calipers. I know a C5 corvette has a thicker disk but I need the offset for the clearance. Any suggestions???
Old 02-04-2010, 08:21 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
You might contact www.vbandp.com and see what they have available.
Old 02-05-2010, 08:50 AM
Serpa69's Avatar
Thanks for the response. I now Baer brakes uses a C5 caliper on a different rotor but they wont give me the part number of the thicker rotor with the correct offset.
