Old 02-07-2010, 12:10 PM
Jr's Avatar
Jr Jr is offline
Default Brass fittings on fuel line
Hello,
After I replaced the fuel pump on my 350, I have a fuel leak out of the brass fitting connected to the fuel pump to the carb(still using the hardline from the factory). Is there a trick to working with the brass? This little piece of brass has be frustrated like you wouldn't believe(some of you may understand where I am coming from). I would appreciate any help on this subject.
David
P.S
This is on my 70 C-10.
Old 02-07-2010, 12:15 PM
The flare may very well be worn out on your hard line. I'd pull it apart and inspect the seat and flare.
Old 02-07-2010, 12:18 PM
eville's Avatar
eville eville is offline
Also on those flare fittings, you need to use a line wrench. Lot's of people try and use an open end wrench, and that tends to 'round' the hex part of the fitting off. Once this happens you can't really get them tight enough.....
Don't use teflon tape!
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
Old 02-07-2010, 04:51 PM
Jr's Avatar
Jr Jr is offline
I think my flare fitting might be done.
Why should I not use teflon?
Old 02-07-2010, 05:11 PM
eville's Avatar
The seal is with the flare, not the threads...
Steve
Check it out Here
Old 02-07-2010, 05:53 PM
Jr's Avatar
Jr Jr is offline
Word.
I am not sure if this fitting is flared, compression, or universal.
Old 02-07-2010, 07:29 PM
Are you at the fuel pump end or the carb end of the fuel line? I may be thinking too late into the 70s but does this truck have a Qjet on it with the filter inside the portion where the fuel line enters the carb? If so, there's a thin plastic washer that seats onto the end of the large fitting and seals against the carb.
Old 02-07-2010, 08:53 PM
It needs a brand new line. All these bandaids are a waste of time.
Old 02-07-2010, 09:12 PM
Doesn't get any simpler than that Todd...
Stuff does get worn out... and a leaking fuel line is nothing to try to put lipstick on.
Old 02-07-2010, 10:18 PM
Jr's Avatar
Jr Jr is offline
This is the fuel pump connecting to the lead pipe to the q-jet.
