Old 02-10-2010, 07:17 AM
wookham's Avatar
wookham wookham is offline
Default Need Help..dash Install
Ok Guys Im Asking For Help
I've Seen It Done But Before I Tackle It I Would Like To Talk To Someone.who Has Put A Late Model Trans Am Dash Into A 71 Camaro
I Have The Dash And I Have The Car...looks Like Im Going To Have To Remove Some Metal From The Car To Do It And Also To Make Some Brackets.................i Don't Have Alot Of Help Or People To Bounce The Ideas Around With So I Have To Do It Right The First Time.
Thanks In Advance And Look Forward To Hearing From Someone Soon
Old 02-10-2010, 08:00 AM
I will throw my opinion where I should probably shut my mouth.
Are you sure you want to do that? That is a welcome to 2004 modification if there ever was one. I know of a couple people reversing this modifcation.
Frank Serafine
Old 02-11-2010, 01:51 PM
Yep -- ^^^^^^^ What he said.
Old 02-11-2010, 02:18 PM
907rs's Avatar
907rs 907rs is offline
A constructive reply would probably help the OP out tremendously.
Bill
Old 02-11-2010, 03:11 PM
Sorry Bill -- you're absolutely right! My apologies to the OP'r.
I would say that this is one of those "fab jobs" that if you have to ask -- it might be a little difficult to explain how it's done....
Old 02-12-2010, 06:58 PM
wookham's Avatar
Default dash
wow.honestly not what i expected from you guys...esp since one of your feature cars has it done..guess he must be a dumb as me huh....oh well guess i'll go right to the source and ask the guy that did it. all i wanted was some ideas on how to go about it
Old 02-12-2010, 07:03 PM
I agree with them Wookham. If you don't care about resale and it floats your boat, go for it. Otherwise I'd stay with something that appeals to the masses a little more.
Old 02-12-2010, 07:15 PM
wookham's Avatar
Default dash
todd
very true but all the cars out there look the same wanted something a little different..........resale isn't an issue ...and if it's done nice enough it will get sold
Old 02-12-2010, 10:00 PM
Then I'd look at the original frame work of the 2002 dash and see if it can be modified to fit your body. Some photos would definitely help. Sounds like a pretty detailed oriented job. I would absolutely contact anybody that has done a similar swap. Been there done that is always valuable info.
Old 02-14-2010, 08:09 AM
MWCC's Avatar
MWCC MWCC is offline
It's not very difficult, it just takes a heck of a lot of time, especially since its your first time. You will be using a little of this and that and doing a lot of fab. It would be best to have the donor car right next to you so you can check how it was installed and then transfer that to the project car. Measure, measure, measure and you'll get it. You'll have it in and out more times than you like, but patience will pay off. Remember, its easier to remove material than it is to add it. Measure 5 times and cut once and always take a break to clear your head when you get frustrated.
Nick @ MWCC
Complete Turn-Key Restorations, Customizing & Fabrication
419-523-6900
www.m-w-c-c.com
