Old 02-15-2010, 05:09 AM
Moabdude's Avatar
Moabdude Moabdude is offline
Default What stall for my TH400
I have a 400SBC with performer intake, Doug Tri-Y headers and Demon 600carb.
No fancy things like cam or aluminum head upgrades (yet)
I think it has about 300 Hp. My rear end has 2.75 gear ratio and the transmission is a TH400.
Use of my car will be mainly street.
What stall would you advise?
>68 Camaro pro touring, 400SBC, 18" Intro's, T4 13" Baer Eradispeed, Airride, Speedtech, Autometer, König seats, March, Magnaflow. Hope to finish in 2006...2007...2008…2009...2010...2011...Yes, 2012 and its finished (well, will it ever be finished )
>69 Nova project, LS1/4L60e, Corvette C5 calipers+rotors, AFX spindles, 69 Camaro body mods, Just got it painted.
Old 02-15-2010, 02:50 PM
thedude327 thedude327 is offline
The duration of the cam and the rear axle ratio are the 2 biggest factors when chosing a converter stall speed. With a mild 400 and the gear you have now, 2000 stall max, but, if you decide to go with a mild cam of around 224-230 duration @ .050 and a rear gear between 3.42:1 and 3.73:1 ,then you will need a 2400-2800 stall converter. The cam specs here are mild so that you will still have a decent idle quality and the vacuum modulator on your trans will still function properly.
Good luck!!
Paul
1973 Z28 Street-touring project.........
Old 02-24-2010, 03:58 PM
6D9 6D9 is offline
Good luck!!
Paul
x2...good advise
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
