Old 02-23-2010, 08:21 AM
GMracer's Avatar
GMracer GMracer is offline
Default Ford 9"
So I'm looking into installing a 9" in a project, and curious if it's worth it to upgrade to a aftermarket unit. Or if I get a rust free stock one off Craiglist and install a back brace it would be more than sufficient. The plan is around 800 HP, twin turbos. Detroit trutrac rearend with 4.88s. Big ford ends, narrowed to fit a wider set of wheels. Any input is appreciated, thanks!
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 02-23-2010, 03:25 PM
Personally I would buy one from the manufacturer you are going to need for your axles. The housings aren't that expensive anyway, and you can have them come braced, made to your width with a drain plug, vent, small or big bearing ends, etc. They will also be to blame if the axles don't fit properly. You can still use a stock type housing, its just easier this way.
Old 02-23-2010, 04:56 PM
Payton King's Avatar
Default I may have one for you
has 4000 miles on a fresh 9 inch. I am keeping the center section. housing with the big bearings and moser 31 spline axles. what width do you need?
Old 02-23-2010, 08:07 PM
GMracer's Avatar
Got to measure it.
Nick Schiffer
Special Thanks to:
Old 02-23-2010, 08:16 PM
JustinB's Avatar
JustinB JustinB is offline
Nick, I would consider going with the Wavetrac and 35 spline axles as opposed to a Trutrac and 31's with that kind of HP. Curry also has a killer new Fab 9 housing. Give me a call and I can put together a few Curry quotes for you.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 02-24-2010, 09:00 AM
GMracer's Avatar
The wavtrac is nice, but I'm not sure I want to swing the money. We'll see, I've dealt with moser a few times now and if I go fabbed I was thinking about going with there unit. I'll have to look into the curry on.e
Nick Schiffer
Special Thanks to:
Old 02-24-2010, 10:35 AM
Default tried to send you a PM but your
box is full.
$870 new from Moser...I will go $450
Old 02-24-2010, 10:46 AM
JustinB's Avatar
What are your plans for the car and what trans do you plan on running?
Justin Butler
Old 02-24-2010, 12:28 PM
GMracer's Avatar
woops didn't realize it was full I'll empty it.
$450 PM me what that includes, possibly any pictures?
And it'd be going in my silverado. I want to get rid of the 14b SF I have in it now. So t56 trans.
Nick Schiffer
Special Thanks to:
