Old 02-28-2010, 12:10 AM
55Sedan 55Sedan is offline
Default $300 too much for a used 9" 3.50 Posi?
I found a used (but "in excellent condition") 9" center section with 3.50 gears and 31-spline limited slip posi on craigslist a few hours from my house. I don't have to pay shipping. He says the posi looks new and gears are in great shape. Is it worth it?
Going in a 55 Chevy Sedan with BBC and Muncie (unless I get a great deal on something like a T56). I'm going to be getting a housing built from Currie, Moser or Strange.
Larry
Old 03-01-2010, 11:56 AM
Apogee Apogee is offline
Larry
FWIW, the 3.50 gear ratio, 31-spline dropout is the most common configuration in the wrecking yards since that's what most of 70's F150 (up to '83) pickups and E-150 (up to '86) vans used. Limited slips, as denoted by 3L50 on the gear ratio tags are the Ford Trac-Loc units. While decent limited slips, they are a clutch type design, so the only way to test them is to measure the break-away torque, not very easy to do with just the center section. The Trac-Loc units are somewhat infamous for breaking the OE cast carrier housing cap. Currie makes billet steel versions that hold up a lot better under severe use.
I blew up a Trac-Loc in my pickup and grabbed a new used center section for $150 IIRC, so $250 isn't outrageous but seems a little steep to me. Whether it's worth it or not is up to you.
Tobin
www.kore3.com
Old 03-01-2010, 01:39 PM
70rs's Avatar
70rs 70rs is offline
Check you local pull a part salvage yard. They are 85 bucks each here.(Washington) That is a complete housing, center section, axles and backing plates. Brakes are an extra 35 bucks.
Eric
Old 03-02-2010, 04:24 PM
osdmike's Avatar
osdmike osdmike is offline
Also remember there are different center sections/carriers.
Some stronger than others.
See info here:
http://www.kevinstang.com/Ninecase.htm
Old 03-08-2010, 01:17 PM
ZMAN1969's Avatar
ZMAN1969 ZMAN1969 is offline
Default ford 9"
last one i got was like 50$ at a pick-n-pull courtesy if a 4x4 Bronco 3.50 rato and trac-lock - seems comon
'69 Trans Am clone under construction -still!
LS6 6speed
69 R/S Z28 Daytona Yellow 302
90 Formula / Firehawk clone
1999 Firehawk
1969 Chevelle SS 396
