Old 11-28-2005, 06:56 AM
mrgto mrgto is offline
Default Anybody making a bolt in Rack/Pinion Steering for A-bodies?
I see plenty of kits for the F-bodies but nothing for A-Bodies. Has anyone installed a Rack and Pinion steering in a A Body? Thanks.
Old 11-28-2005, 08:30 AM
TravisB TravisB is offline
I have but it has some issues right now.....no one makes a kit for it tomy knowledge!
Kenny Davis Hot Rods
Old 12-03-2005, 12:04 PM
68-GTO 68-GTO is offline
TravisB, you've installed a rack n' pinion on an A body?
what year A body?
What are the problems your experiencing with it?
Im not sure if im looking into this mod yet, its just interesting to see some options out there.
thanks, Brian.
Old 12-03-2005, 01:29 PM
kp.touring kp.touring is offline
Default GTO/A-body Rack
Why not just use DSE steering box it uses a rack style servo. I drove a 70 GTO today that we used that box in and you get the same feed back from it that you do with a rack and pinion set up without the problems of try to put a rack into a chassis that was never designed to have rack and pinion steering.
Kevin
Campbell Auto Restoration
Old 12-05-2005, 06:42 AM
astroracer astroracer is offline
Take kevins advice and stick with a recirc. ball box. Putting a R&P in anything takes a lot of design work and just any rack will not work. The inner tie rod points need to be in the correct relationship to the upper and lower control arm pivots not only fore & aft but side to side AND up and down. Not taking these points into consideration will give you an ill handling car with outrageous bump steer, ackerman and turning radius issues. Leave the racks for the racers with revised geometry and go with an updated box...
Just my 2 cents
Mark
"Bad Ast" Astro Van Pro-Touring Project.... Heat, beat, file to fit, paint to match...
Old 12-05-2005, 07:56 AM
what year A body?
thanks, Brian.
Having a very difficult time getting the bumpsteer issue resolved.....been working on it for awhile and it is still not right probably gonna have to go back the steering box set up!
Old 12-05-2005, 08:15 AM
Don't know if you have looked at this site...
http://www.longacreracing.com/articles/art.asp?ARTID=13
The suspension AND rack design need to be coordinated to get the points to match the illustration at the bottom of the article. If you can't do that with your combo you need to go back to the drawing board.
I designed the front suspension for my van around a Corvette R&P. That is what I used as a starting point and then developed the entire suspension around those inner pivot points. Just slapping any old rack into an existing suspension will cause more grief then it is worth, as many of you have discovered...
Mark
