Old 03-25-2010, 07:26 PM
Default Best air DA Sander
Hi guys,
Looking to buy a new DA sander and a long board sander. Been using this 3m type at work and they work great.
http://www.3mfinishingsystems.com/ra...talSanders.cfm
http://www.repaintsupply.com/pd-3m-2...tal-sander.cfm
Just wondered what the folks that use them every day feel are the best DA's out there in a given price range ?
Thx for your input !!
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 03-25-2010, 07:29 PM
GM Muscle's Avatar
i use a dynabrade da. i like it because its industrial and made of a hard composite plastic. its very light and you can buy them with different strokes. ive been using the same one for 8 years now.
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 04-02-2010, 11:54 PM
OOCustoms's Avatar
OOCustoms OOCustoms is offline
Ive got a dynabrade and Im very happy with it. Pretty tough too!
Old 04-05-2010, 05:04 PM
mild2wild mild2wild is offline
Another vote for dynabrade.
Old 04-06-2010, 02:57 AM
deuce_454's Avatar
i LOVE my dynabrade... its tough, light, doesnt get freezing cold when in use and its quiet and powerfull
Jake: Hit it.
Old 04-07-2010, 01:32 AM
NBR521 NBR521 is offline
Dynabrade's are inmho the best DA's out there. I use them everyday and have been very happy. They are very comfortable and very well balanced. They are usually about $350 and well worth it.
I have used various others such as 3M, Snap-on, Matco, etc. and honestly feel that the Dynabrades are the way to go.
Old 04-08-2010, 07:36 AM
Streetwerkz's Avatar
Streetwerkz Streetwerkz is offline
Dynabryde, and Hutchkins are what I have, and have not used anything better.
www.STREETWERKZ.com
Custom Powder Coating, and Media Blasting
Old 04-11-2010, 06:57 PM
elitecustombody's Avatar
Had Dynabrade for years,also have Hutchins,but they seem to be alot heavier,so I don't use them much
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 04-13-2010, 07:38 PM
brans72 brans72 is offline
Which dynabrade model are you guy's using for body work? I will be looking for one shortly. Thanks Brandon
Old 04-16-2010, 09:46 PM
JRouche JRouche is offline
I just bought a dynafile (DYNABRADE 15006) from enco. Was a good price with the 20% off. Not a DA, I have an Ingersoll sander for that (not great).
The small band file comes in handy for work where the small 1-3" disc sanders cant get in. Say you have a small square or rectangular tube and you need to get inside of it to clear out some weld through or just remove some material.
The dynafile I got has a small arm for tight places. I also have the one with the longer arm. But its also thicker and wont get into as tight of a space.
The band files are a dream to use when the need comes up.
Oh, and it seconds for a angled die grinder if needed. Dynabrade air motors are pretty nice.
Ok, Im crazy for tools so speaking of the band files. I also have a Dotco (Cooper tools) 12L1280-36B2. Its also a 12" belt band file. Its a lil slower then the dynafile but just as quality. Kinda pricey, but a quality tool. Also can second as a die grinder.
Its all in the abrasive though really. I like nortons SG belts. Its a ceramic aluminum oxide. It out performs nortons or 3Ms zirconia belts by a noticeable amount. And and even more so than aluminum oxide and we wont even talk about silicon carbide. Where all of those go "flat" pretty quickly with heavy metal grinding, the ceramic AO holds its shape and keeps the original grit longer. So the machine works less, its still cutting and not buffing due to the abrasive still being sharp and not broken down.
The ceramic abrasive is a lil more costly, but from what I have seen well worth the cost. Pick up a belt or disc with it a give it a try.
Oh, and 3M has a ceramic abrasive. They call it Cubitron. I havent used it yet but Im sure its a top quality abrasive. JR
