Old 03-26-2010, 07:18 AM
gmorris gmorris is offline
Default Innovate LM2 AFR Kit
Purchased this kit late last summer and had it installed for about an hour before taking out my cam and putting the car away for the season. Worked very well to dial in my carb jetting and figure out what was going on at part throttle. Now decided to switch to EFI which has it's own AFR logging capability. Everything is as-new and none of the wiring harnesses were even removed from their packages. The 02 sensor was installed for about 50 miles and car was never run without the sensor powered up. This is the complete kit with single 02, retals for $479US, abvailable on ebay for $399US plus shipping.
The LM-2 Kit (Single Wideband O2) includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, analog in/out cable, ODB-II/CAN interface cable, SD memory card, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide. Carrying Case also included! P/N: 3806, MSRP $479
The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s award-winning digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
Patented “Direct Digital” Wideband Technology
Wideband O2 Compatible with ALL fuel types
Single or Dual Channel Version Available
OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data
Log directly to SD card (included)
Playback log data on screen and/or with powerful LogWorks software (included)
Large high-contrast graphics LCD
Built-in RPM converter (direct frequency or with optional inductive clamp)
4 fully-differential analog inputs
2 configurable linear analog outputs
Positive lock connectors for all connections
Innovate MTS serial IN and OUT
USB connection to your PC
The LM-2 also features two fully programmable linear analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR. With the provided LM Programmer software these analog outputs may also be configured by the user.
$300 obo plus shipping. Includes original hard carrying case.
Old 03-30-2010, 07:18 PM
doitbby doitbby is offline
sent pm
