Old 03-28-2010, 07:24 PM
66GTFB 66GTFB is offline
Default What cooling systems are you guys running?
Hey fellas,
Just wondering what cooling systems you guys are running? What radiator, water pump (electric or mechanical), and fans (brand, size, cfm #'s), type of coolant, etc and what sort of temps you see?
I'm running a CSR electric water pump and Ron Davis radiator on my mustang and it just won't run as cool as I want it so I'm going to play around with going back to mechanical water pump setup and see what that does.
Any info would be awesome.
Cheers,
Joe.
Old 03-28-2010, 07:52 PM
pokey64's Avatar
pokey64 pokey64 is offline
Good post! I'm researching upgrading our Camaro's cooling system. The ol 454 is running hot...
Interested in seeing what everyone is running.
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 03-28-2010, 09:04 PM
g356gear's Avatar
g356gear g356gear is offline
BBC..stock 4 core rad, with stock fan....185 degrees average, 195 on a hot day. Ceramic coated headers made a huge difference.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 03-29-2010, 04:12 PM
Any other combos guys?
Old 03-29-2010, 04:37 PM
lil427z's Avatar
lil427z lil427z is offline
ron davis
rick k
Old 03-29-2010, 05:35 PM
chr2002ca's Avatar
69 Camaro with zz454, mechanical water pump, GM BB 7-blade clutch fan, GM BB shroud, 2 core Aluminum BB radiator. Rarely goes over 180 degrees. Has never gone past 195. I agree with the last post, I think the ceramic coated headers significantly reduces the underhood temperatures. My aluminum heads and intake probably help a little too.
Chris Robinson
Old 03-29-2010, 07:01 PM
pokey64's Avatar
Here's what came on our car. The radiator says "Northern" on it and looks like a 2 core. The single fan is a pusher and is around a 10" diameter. The fan turns on with the key and stays on. The water pump appears to be stock. The 454 overheats while cruising around town or if I just let it sit and idle.
The old thermostat had some seaweed looking crud in it so I replaced it. Still overheats so I'm going to try some additional air movement with a big fan to see what happens.
Any other suggestions?
//Ed
//1964 Impala SS
Old 03-29-2010, 10:24 PM
That fan isn't even close to what you need. I'd go with a factory shroud and fan in your situation or a dual electric setup.
Old 03-30-2010, 08:01 AM
chr2002ca's Avatar
Agreed. That little electric fan with no shroud isn't doing much at all to help you out. A properly sized and installed stock fan shroud along with a GM 7-blade fan and new fan clutch should help out tremendously and is probably the cheapest way to go. An electric setup is great too, but might be a bit pricier and you might have to deal with clearance issues, amp draw, sizing, shroud setup, etc. Derale makes a heavy duty flex fan that works nicely also and looks good too, but it's a bit too heavy in my opinion(I tried it).
The setup I use which is rather simple but works great for me is:
fan: GM 18 1/4" seven blade, Classic Industries G8354
shroud: GM NOS, Big Block 69 Camaro, Ebay
clutch: Thermal, 3" depth, big block application, local parts store
Just be sure your belts are fresh and tight because it will put a little extra drag on your water pump pulley, especially at high RPM.
Whatever you decide to go with, good luck!
Chris Robinson
Old 03-30-2010, 08:09 AM
SLO_Z28 SLO_Z28 is offline
Single core aluminum radiator with plastic tanks and a 16 inch Hayden fan in the stock shroud. Also have a high volume edelbrock water pump. Can idle all day long in 110 weather.
