Old 12-02-2005, 08:17 PM
mini69's Avatar
mini69 mini69 is offline
Default dse fuel tank
ANYBODY HAPPEN TO KNOW THE DIMENSIONS OF DSE GAS TANK . ANY INFO WOULD BE APPRECIATED
Old 12-03-2005, 09:38 PM
Speedster's Avatar
Speedster Speedster is offline
Default Mini69 - DSE Fuel Tank
I looked up that tank info in the hardcopy catalog and there are no dimensions listed. You will probably have to call DSE at 704-662-3272. Lindsay usually picks up the phone and knows that stuff.
-Bruce
Old 12-03-2005, 11:31 PM
Van B's Avatar
Van B Van B is offline
If you need the dimensions of a first gen Camaro narrowed tank for mini tubs I can measure mine.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 12-04-2005, 07:31 AM
mini69's Avatar
Post
hello jeff if you could measure your tankthat would be great.
Old 12-04-2005, 11:50 AM
Van B's Avatar
Here are the dimensions.
Width 35"
length 19" (front to back when mounted in car)
depth 8" at front then it tapers to approximately 4.5" at the rear
Hope this helps.
Jeff
99 Miata LS6
Old 12-04-2005, 01:12 PM
mini69's Avatar
thanks alot for the info
