Old 04-04-2010, 08:26 PM
YENKO/SS's Avatar
YENKO/SS YENKO/SS is offline
Default 69 Camaro clear/smooth front signal lens????
Just installed a set of Spaghetti Engineering's LED front parking/ signal lights and they are killer. A small circular compilation of LED'S, surrounded by a larger circular of LED'S for a cool looking starburst effect. However all those LED'S are lost when you re-install the factory clear lens with all the refractors inside the lens. Does anyone make a clear/smooth lens to show-off those LED'S????????
Old 05-12-2010, 01:51 AM
SILVER68 SILVER68 is offline
Default one way is to sand the ridges all the way down
once you sand it down with rough, go higher and higher in grit until smooth, then you can wet sand and apply polish. or once smooth use one of those headlight lens recovery kits, which help you do the same thing.
Old 05-12-2010, 10:05 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
In Sacramento there is a place called Tap Plastics that could make you the parts or pick up the material and do it yourself. Look for a plastics place around your area. You could get clear, or a light tint to the plastic.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
