Old 04-05-2010, 05:40 PM
jake72ss jake72ss is offline
Default upper a arm cross shaft
I have been trying to find a supplier that sells upper a arm cross shafts that have the provisions for caster slugs like the DSE a arms. I've found them that have a 6" bolt center, but not 6.5" for a chevelle. I have global west uppers now and I would like to change the ball joint sleeve to a screw in style and change out the cross shafts to the style I mentioned earlier. Any help would be great, Thanks,
Jake
Old 04-05-2010, 09:42 PM
JRouche JRouche is offline
Not sure of the slugs you are talking about. What are they?
SWS sells a cross shaft for the chevell. But its meant to be used with metal bushings.
http://www.southwestspeed.com/?sec=view_part&id=14391
Here are the arms they use with those shafts, screw in ball joints but for mustang spindles.
http://www.southwestspeed.com/?sec=v...0Racing%20Arms
Here is there stock arms.
http://www.southwestspeed.com/?sec=view_part&id=28398
Old 04-06-2010, 02:56 AM
deuce_454's Avatar
check sc&c (www.scandc.com).. the adjustable spc arms are caster/camberadjustable, so there is no need to rempve the arm and changing out the slugs.. i have a pair on my malibu and they are awesome quality!
Jake: Hit it.
