Old 04-06-2010, 05:02 PM
M.Hearn's Avatar
M.Hearn M.Hearn is offline
Default Clear coating / colored clear coatedCabon fiber parts?
I am wanting to put a colored clear coat or tranparent color coat on my carbon fiber parts.
What is the best way to do this?
I will be using either HOK or Auto Air Color products on the rest of the car. Which is easier to work with and has better outcome.
Daily Driver - 2001 Peterbuilt 387
Off Duty / Home time Driver
Custom bult 1927 XL27 roadster
Adurn Aluminum block OHV conversion Flathead with Povitn front mount blower and Hilborn fuel injection, Witers quick change rear axle, 5 speed, 3 pedals, no-top, Steel bodied with suicide style 5 " drop front axle.
Current Project, Carbon fibered body version. With 434 aluminum block motor with Kinser fuel injection and t-56 trans and winters quick change rear axle, billet specialties wheels
Old 04-06-2010, 08:45 PM
NsaneHotrodz's Avatar
NsaneHotrodz NsaneHotrodz is offline
throw some kandy on it!
www.nsanehotrodz.com
Dewayne Morgan
[email protected]
Old 04-06-2010, 09:19 PM
M.Hearn's Avatar
I am needing to know if I can tint the first layer or two fo the clear coat or should I use a transparent paint of some type?
Pearl is planed if I can do what I am wanting to do.
I am wanting the carbon fiber to show through but wanting to get a little bit of color to blend it better with the rest of the paint job.
Old 04-07-2010, 05:10 AM
redfire69's Avatar
redfire69 redfire69 is offline
Any silver based candy might look good. Mask off the CF for the base, then paint over with a few coats of candy mid-coat. I would try some test pieces... good luck!
Ron
69 Camaro Redfire
Old 04-07-2010, 08:54 AM
M.Hearn's Avatar
My orginal plan was to go with a Metallic Cobalt blue with Graphite pearl for the painted portions of my body work. SO I am looking for a lighter blue for the CF.
But a blue silver mix would look good also or how would a lighter blue with a silver pearl look?
Old 04-07-2010, 09:29 AM
redfire69's Avatar
I would find a tri-coat kandy or pearl like House of Kolor and buy some samples to spray some tests on sections of CF stock. It would def give a custom look.
Ron
69 Camaro Redfire
Old 04-07-2010, 10:56 AM
You can mix any kind of metallic / pearl in a binder coat (transparent base), then clear over the top of it. Depending on how much of a color effect your after.
Jeff Allen
J2 Speed and Custom
