Old 04-07-2010, 06:34 PM
g356gear's Avatar
g356gear g356gear is offline
Default Dilemma on Engine/trans Combo for my 69 Camaro
I have been looking at swapping out my stock 350hp 396 for something with a little more edge to it. I want to stick with the big block theme. I have decided on a Mark Jones forged 496 stroker....650hp and 675 ft.lbs. The dilemma is what to put behind it.
Option #1 Built TH400 to replace the existing original TH400. Would have the old muscle feel and no mods to make it work. I don't do much hwy driving so it is an option. I have 3.31 rear gears in the car.
Option #2 Built Stage 3 Keisler 4L60 with their conversion kit package. Again, minimal modifications but some work needs to be done to make it work. I am also unsure of how good the parts and modifications are that Keisler does to their stage 3 transmissions. It's a bit of an unknown. I have an upgrade list but am a little uncertain.
Option #3 Hurst Drivelines TKO-600 swap package with their Mcleod dual disc clutch and other upgrades. Due to some packaging constraints, I would need to do a custom Wilwood pedal set up with under dash master cylinder running to a an external slave cylinder on the trans. I know they make good kits and their service is excellent, its just the amount of under dash work needed to make the system work.
Option #2 and #3 around about 3K more in cost and require modifying the car much more than staying with the TH400.
Thanks for the input guys.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 04-07-2010, 06:51 PM
JamesJ JamesJ is offline
I am a stick guy so I say #3 but if you dont care just save the cash and keep it simple and do #1 you will be back on the road sooner....
James J.
