Old 04-17-2010, 11:54 AM
brownz brownz is offline
Default ? on DSE mono to multi leaf conversion kit. have a issue
i have a 1970 nova and im using the dse mono to multi leaf conversion kit. when i installed the kit i have a space between the rear end and the upper locating pad, and when i put the car in gear or drive down the road it makes noise and rattles because its loose. what do i need to do to correct this issue? its on both sides. its like the upper pad needs to be thicker?
Brandon
Detroit Speed Engineering
Kyle & Stacy Tucker's Detroit Speed & Engineering
Old 04-17-2010, 05:37 PM
WILWAXU WILWAXU is offline
Did the spring not fit into the hole?
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 04-18-2010, 07:53 AM
yes it fits in the hole great just have the gap between the rear end housing and the spacer plate.
Old 04-18-2010, 11:14 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Can you post a picture of this gap for us?
Curtis
Old 04-18-2010, 07:10 PM
Put the same kit on my Nova a little over a year ago without issues, probably best to post a picture.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 04-19-2010, 12:12 PM
i called dse and they said that they have had this issue and to use the cushions that came with the kit or have the blocks machined down to the correct size. i thought the 85 bucks it cost it would work so i just used a cushion that came with the spring kit and it seems to be ok
