Old 04-18-2010, 11:52 PM
sixnina's Avatar
sixnina sixnina is offline
Default windshield problems please help!!!!
First of all thanks in advance to those who respond. I have been working on my 69 camaro for the last 3 years putting it together as money permits. Recently tried to have glass guy install windshield, as the car did not have one when i aquired it. Problems arose when new windshield was set in place and on the drivers side it contours to dash well. Glass guy told me window has to lay flat along window channel because it gets glued down like on newer cars. This is where the problem begins because on passenger side the windshield sits about 3/8 -1/2" off the dash and window channel. i buzzed down the dash to find a small amount of filler and that helped to bring the windshield closer but i can still fit my finger under the corner. Has any one ever ran into this? can dash be adjusted or is it welded in? Any help is greatly appreciated. Thanks, Shane
Old 04-19-2010, 07:02 AM
elitecustombody's Avatar
does it bulge out and won't sit flush or it's too short on the bottom corner? Hvae you measured the glass to make sure it has proper dimensions?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 04-19-2010, 10:59 PM
sixnina's Avatar
Default window problems
it bulges out and wont sit flush. does anyone have the dimensions a 69 camaro glass should be? Its brand new via the glass guy.
Old 04-20-2010, 07:36 AM
What brand is the glass from?Do you have the old glass? I'd compare them both,but it almost sounds like you have alot of filler
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 04-21-2010, 07:56 PM
sixnina's Avatar
not sure what brand but will check. the dash had a little filler but i buzzed it down to bare metal and still had issues. Unfortunately i never had the original glass so nothing to compare it to.
