Closed Thread
Old 04-23-2010, 03:59 PM
camaro73 camaro73 is offline
Default 1973 z28
This is a 1973 z28 for sale, 377ci engine, This car handles great,sound great, You will not be able to build this car for what I am asking. This car is turn key ready for you to enjoy this summer.
400 4 bolt main
.40 over
350 steel crank
GM polished rods
10.1 Compression
280 comp cam
AFR aluminum heads 195
Hooker Jet Hot coated headers
Flow master exhaust
Roller rockers
650 Demon carb
Edelbrock RPM airgap manifold
TCI starter
Billet steel flywheel
Be-cool aluminum radiator
Dual 13’ fans
6 Speed Richmond transmission
Long shifter
Dennys Aluminum 3.5” drive shaft
12 bolt 3.31 gears
Superior axle
4 wheel disc brakes
Drilled / Slotted performance rotors.
Wilwood up front GM in back
Stainless steel brake line.
B body spindles
Close ratio steering box
Centerline starlite wheels
275/40/18 0n rear
255/45/17 up front
Falken Performance tires
Hotchkis 2” drop in front with sway bar.
Detroit speed rear 2’ drop springs in back
Urethane bushings
All new GM glass
location is Wisconsin
$26000.00
920-427-1373
Old 04-23-2010, 05:35 PM
732ndgen 732ndgen is offline
Default camaro
are you intrested in trades. I have a sligly used saturn and a really used girlfriend. (i hope you dont repeat that one) you cant get rid of this beast it seams like you just got it from me we still on for the face off at road america?
Old 04-26-2010, 06:09 AM
jy211's Avatar
jy211 jy211 is offline
Sorry said pic's of used girlfriend are not loading?
Old 06-26-2010, 07:50 AM
JNS JNS is offline
did you sell this?
Closed Thread
