Old 04-28-2010, 01:29 PM
brans72 brans72 is offline
Default wheel well welding/smoothing pics or other body work pics lend me some advise please!
We just got the pass side outter wheel well tub in place and spot welded it but I am always grinding away to much to make it smooth! So can you guys post up pics of what it looks like on your car for me. I will take any type body work tips with welding and smoothing the welds down correctly. I think maybe I am being little picky since my first true muscle car and body work or maybe I need more pratice. Any tips/info fellows? Brandon
Old 04-28-2010, 01:34 PM
Be more careful?
It's easy to take too much off.... keep your grinder flatter if you're digging into the metal AND WATCH where you're grinding... you should be able to clearly see when you're grinding the "weld" and when you get into the sheet metal surrounding it. Don't grind into the surrounding metal any more than you have to in order to make it "flat".
Changing discs might help you with this. Use an aggressive grit to start.... knock the weld down - and switch to finer grit - finish with a 3M "pad" and even these come in various "grits" (they're not measured in grit - but you get the drift).
Old 04-28-2010, 01:44 PM
i am using green rough sanding disc from roloc/3M got a shoe box full. I can get a few pictures if you would like of my learning body work! Thanks for tips Greg.
Old 04-30-2010, 05:42 AM
The discs are good for finishing the welds not grinding them down. I like 3M's 01991 3" grinding discs. You put them on a 3" grinder, and they eat the welds down quick! But only take them 90% of the way flat, then finish them off with the roloc discs 36 first, 80 next, then the red scotch brite. If you want it to look perfect you can then DA them with 180, 320.
Jeff Allen
J2 Speed and Custom
Old 05-03-2010, 04:46 PM
redss86 redss86 is offline
Exactly, knock it down first then finish.
Joe
