Old 05-03-2010, 09:50 PM
Saleen04 Saleen04 is offline
Default 70 Chevelle 4 wheels disc conversion
I've been away from hot rods for a couple of year and just picked up a 70 Chevelle project car. I'm looking to do a 4 wheel disc conversion as it currently has drums all the way around. Since I have a several major projects on the car I'm looking for the best without breaking the bank.
The is being built as a street car and will have between 400-500 HP.
I would be open to finding used breaks as well such as a Z06 or C5 setup just not sure what will work.
Can you make suggestions which are good kits to go with?
I've see this on ground up:
http://www.ss396.com/mm5/merchant.mv...AKECONVERSIONS
Old 05-03-2010, 09:56 PM
brans72 brans72 is offline
Kore3! Tobin will give you all the info you want,stocks parts and has tons and tons of knowledge, not to mention friendly! Website is Kore3.com
